Distinguished Guru
Message 11 of 15
Re: HH3 and BT WIFI/FON
@flipper wrote:
Why is it when I log on to my HH3 it says this service is not activated? When i click activate not and check my status it says im activated for this service, and yes i do use it and it also says no minutes used??
Any ideas? just curious.
If you really want your hub to transmit these, simply (which will restore the hub and you may lose any user made changes) press the red recessed button and it will show your hub as active.
-+-No longer a forum member-+-
flipper
Message 12 of 15
Will this then tranmit a bt openzone??
Obviously this will disconnect me too and I dont want to do this at the moment due to my other problems...but once sorted i may try this, thanks.
Distinguished Guru
Message 13 of 15
Yes it will.
flipper
Message 14 of 15
All sorted now guys, found some other threads on here about it, simple, but a pain, unsubscibe then re-subscribe. Sorted.
All showing active and now transmitting!
Thanks All.
Distinguished Guru
Message 15 of 15
Yes, there's that method too, I should of thought about that:(
Anyway, good to hear you sorted it:)
