duderooni
Message 1 of 9
HH3 interface display problem, any ideas?
My interface looks like this, it's really annoying. Only happens when I go on advanced settings in Firefox. In Chrome it looks fine, and other menus in firefox look fine. What's happening and is there a quick fix?
8 REPLIES 8
curiousfellow
Message 2 of 9
Re: HH3 interface display problem, any ideas?
Try deleting your browsing history in firefox then re access the advance settings screen.
duderooni
Message 3 of 9
Tried that, didnt fix it 😞 tried clearing all cache,
curiousfellow
Message 4 of 9
Have you checked FF for updates recently, applied that and re booted you lappie \ pc?
duderooni
Message 5 of 9
Yeah latest version, I've had this problem a while. I've tried deleting and re-installing too.
Keith_Beddoe
Message 6 of 9
Try a factory reset of the home hub.
gg30340
Message 7 of 9
If you have adblocker add ons enabled they can cause this.
See this link for similar problem
http://community.bt.com/t5/Other-BB-Queries/Home-Hub-2-Sub-Headings-Missing/td-p/828818
duderooni
Message 8 of 9
GG30340, top man, that was the problem. Disabled adblocker and it came back straight away. Thanks a lot, I'll now have a good look at the filter settings and sort it out.
Much appreciated, thanks a lot!
pottyperson
Distinguished Guru
Distinguished Guru
Message 9 of 9
Depending on which ad blocker you're using, you may be able disable it selectively by clicking the icon and choosing "Disable on this page only" in the drop down list.
