kensington
Message 1 of 8
HH3 reset always cures disconnect fault?
All hunky dory since March, speeds 11Mb/0.9Mb whether plugged into Hub or wireless but now constant line disconnect problems, the only way I have found to cure the problem is to reset the HH3, usually three to four times a day.
I can open the network and sharing centre to run diagnostics to reset the wireless adapter and BB connection, but that never works, whereas the hub reset works for a varying amount of time.
The only change has been the replacement of the shared services pole in our front garden?
7 REPLIES 7
Message 2 of 8
Re: HH3 reset always cures disconnect fault?
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
kensington
Message 3 of 8
HomeHub 3, hissing on line noise test
ADSL Line Status
Connection Information
Line state:Connected
Connection time:2 days, 03:49:54
Downstream:12.27 Mbps
Upstream:1.121 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):8.4 dB / 6.0 dB
Line attenuation (Down/Up):25.4 dB / 12.3 dB
Output power (Down/Up):20.4 dBm / 12.4 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):3734 / 137
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):10242 / 134
Error Seconds (Local/Remote):3127 / 60
kensington
Message 4 of 8
Can I add that the speed is not the issue, it is the constant loss of either wireless connection to any device we own or visitors tablets / smartphone and or a complete loss of broadband connection momentarilly. That loss of connection can last minutes or seconds and or happen several times per hour and some days not happen at all?
kensington
Message 5 of 8
Maybe the wind is moving the DP and at times enough to break whatever tenuous connection we happne to enjoy? Having been a BT Engineer I have witnessed such things driving a customer round the bend.
As for wireless drop outs, that could simply be the Hub 3 on its way out?
Message 6 of 8
have you tried a new filter and connecting to the test socket as you must already know there should be no noise on the quiet line test
kensington
Message 7 of 8
No this is a combination of poor DP connection & Hub electronics breakdown problem, we are probably going to run a month long intensive test with a third party modem router to prove / disprove the Hub drop out problems. Depending on outcome we shall consider moving onto the DP.
Yes test socket proved noise external to property
Message 8 of 8
the noise needs resolving first before considering trying other routers
