Message 1 of 6
HH3
home hub 3 with latest software everytime i connect my daughters computer with 54mb G my 150mb N drops to 54mb G is there a fix and if not why not lol
recommend a router to replace?
5 REPLIES 5
Message 2 of 6
Re: HH3
Wireless connnects at the speed of the slowest device. You could upgrade the computer`s wireless card.
Message 3 of 6
Re: HH3
doesn't really matter which router you use, when mixing 802.11g & 802.11n the router will always default to the slowest for compatibility. best solution is to have either all 802.11g or 802.11n
free your computer, use opensource
i'm a linux user & very happy about it
Recognised Expert
Message 4 of 6
Re: HH3
"recommend a router to replace?"
Even easier and cheeper is to pop in a USB wireless n adapter.
I Use THIS TYPE  The mini size doesn't stick out from a Laptop too much. Spec HERE
There is an even smaller Nano Version .
The mini and nano would be ok in a laptop but the larger version would stick out too much imho.
There are many other manufacturers of these examples HERE.
I put comparison speed result pics at the bottom of THIS POST.
Please Click On any Text in Blue as that automatically links to information.
PC (NDEGR)
Message 5 of 6
Re: HH3
i had a dlin 615 with ddrwt firmware on when i had cable and got 300mb all the time
Sage
Message 6 of 6
Re: HH3
The HH3 is not "true" dual channel. As with a lot of supposed dual channel routers  it goes down to the speed of the slowest wireless connection. True dual channel routers don't. Then again, they cost more.
