Message 1 of 5
HH3B: slow lan: wireless fast
Hi,
Using a hh3b, I've noticed that my htpc (xbmc) was buffering using the lan.   Moved it to wireless and all was fine.
I plugged my laptop on a lan port on the hh3 and the same thing happened... wireless was fine and didn't buffer.
I rebooted the hh3 and the problem went away for a while.. but couple of days later, the lan issue returned
Anyone come across something like this before?
Update: replace the lan cable... but no difference.
lan speed
before reboot:
Download Speed: 987 kbps (123.4 KB/sec )   Upload Speed: 1022 kbps (127.8 KB/sec )
after reboot:
Download Speed: 34800 kbps (4350 KB/sec )   Upload Speed: 8111 kbps (1013.9 KB/sec )
So, rebooting fixes the issue for a short time... but why?
4 REPLIES 4
Message 2 of 5
Re: HH3B: slow lan: wireless fast
Message 3 of 5
Hi,
Thanks for the thread link.. most are talking about home hub 3a... but I'm on a 3b hub, Software version V100R001C01B031SP09_L_B.
Very odd.
Message 4 of 5
Looks like this is the same issue as I'm getting:
http://community.bt.com/t5/BT-Infinity/Infinity-drops-below-1M-bits-each-day/td-p/524839
Wired lan: < 1mb
Wiressless: 35mb
Reset the home hub 3... everything works at full speed... for a while.
Expert
Message 5 of 5
I also get the same issue as this on my current homehub3 type B 😞 Only way to fix it is to disconnect and reconnect the internet!
