Hi,
I'm hoping this is the correct forum to ask this question. I want to increase the quality and range of wireless coverage in my house. Would it be possible to do this using HH3 -> Powerline -> Powerline -> Wireless Access Point.
I have old Sky Wireless G routers that I could configure into Access Points if this is an option.
Regards
OW
That should work. Don't forget you need to connect to the Lan port on the router when you use it as an access point. Also, if you use different channels but the same security details on the HH3 and the access point I believe it makes roaming about the house work better (based on other posts, never tried it).
