Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
Hello BT,
After a few years of good strong connection, my Infinity broadband has started dropping out pretty regularly. Looking at this forum, it seems others are having similar problems. I can 'see' the drops in the log of my home hub manager. I have pasted one example below (there are many like this). I hope pasting it here it helpful to figure out what is going on? I've just been on the telephone with BT and they said they're 'refreshed my line' whatever that means. Unsure if it's made a difference yet. Hopefully.
James
PS: Have masked some of the IP addresses. Wasn't sure if necessary, but didn't think it'd do any harm.
14:12:27, 24 Aug. (527809.250000) Admin login successful by 192.XXX.X.XX on HTTP
14:12:21, 24 Aug. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.XXX.X.XXX]:59895->[52.5.47.244]:443 on ppp1)
14:12:21, 24 Aug. OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.102]:44732->[64.233.XXX.XXX]:5228 on ppp1)
14:12:21, 24 Aug. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.XXX.X.XXX]:41019->[174.36.210.37]:5222 on ppp1)
14:12:21, 24 Aug. (527803.490000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
14:11:58, 24 Aug. (527780.590000) PPP IPCP Receive Configuration ACK
14:11:58, 24 Aug. (527780.500000) PPP IPCP Send Configuration ACK
14:11:58, 24 Aug. (527780.500000) PPP IPCP Receive Configuration Request
14:11:58, 24 Aug. (527780.330000) PPP IPCP Receive Configuration NAK
14:11:58, 24 Aug. (527780.230000) PPP IPCP Send Configuration ACK
14:11:58, 24 Aug. (527780.230000) PPP IPCP Receive Configuration Request
14:11:57, 24 Aug. (527779.970000) PPP IPCP Send Configuration ACK
14:11:57, 24 Aug. (527779.970000) PPP IPCP Receive Configuration Request
14:11:57, 24 Aug. (527779.880000) PPP IPCP Send Configuration Request
14:11:57, 24 Aug. (527779.880000) PPP IPCP Receive Configuration NAK
14:11:57, 24 Aug. (527779.700000) PPP IPCP Send Configuration ACK
14:11:57, 24 Aug. (527779.700000) PPP IPCP Receive Configuration Request
14:11:55, 24 Aug. (527777.600000) PPP IPCP Send Configuration Request
14:11:52, 24 Aug. (527774.080000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
14:11:52, 24 Aug. (527774.080000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
14:11:49, 24 Aug. (527772.000000) PPP IPCP Send Configuration Request
14:11:49, 24 Aug. (527772.000000) WAN operating mode is Ethernet
14:11:49, 24 Aug. (527772.000000) Last WAN operating mode was Ethernet
14:11:47, 24 Aug. (527769.950000) PPPoE is up
14:11:47, 24 Aug. (527769.940000) CHAP authentication successful
14:11:47, 24 Aug. (527769.870000) CHAP Receive Challenge
14:11:47, 24 Aug. (527769.870000) Starting CHAP authentication with peer
14:11:47, 24 Aug. (527769.860000) PPP LCP Receive Configuration ACK
14:11:47, 24 Aug. (527769.860000) PPP LCP Send Configuration Request
14:11:47, 24 Aug. (527769.860000) PPP LCP Receive Configuration Reject
14:11:47, 24 Aug. (527769.850000) PPP LCP Send Configuration ACK
14:11:47, 24 Aug. (527769.850000) PPP LCP Receive Configuration Request
14:11:47, 24 Aug. (527769.850000) PPP LCP Send Configuration Request
14:11:23, 24 Aug. (527746.020000) New GUI session from IP 192.168.1.77
14:11:19, 24 Aug. (527741.600000) CWMP: session closed due to error: Could not resolve host
14:11:18, 24 Aug. (527740.220000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
14:11:18, 24 Aug. (527740.220000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
14:11:16, 24 Aug. (527738.210000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
14:11:13, 24 Aug. (527735.220000) PPPoE is down after 8361 minutes uptime [Disconnected]
14:11:08, 24 Aug. (527730.890000) PPP LCP Send Termination Request [Peer not responding]
Welcome to the ever growing club of HomeHub 5 pain.
I'd suggest popping your Router stats in here as i imagine the mods may ask for it 🙂
Sorry for being a noob, but where do I get those from @Bicceh ?
so head over to your router page, then it'l be under Troubleshooting > Helpdesk IF it's the Hub 5 🙂
As yes. Here we go Cheers @Bicceh.
You don't have a Homehub 5 you have a Homehub 4.
Good spot. Sorry. I'll change my post title.
Just happened again
15:51:34, 24 Aug. | ( 4752.510000) CWMP: session completed successfully |
15:51:34, 24 Aug. | ( 4751.810000) CWMP: HTTP authentication success from https://pbthdm.bt.mo |
15:51:18, 24 Aug. | ( 4736.070000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username |
15:51:18, 24 Aug. | ( 4736.070000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
15:50:56, 24 Aug. | ( 4714.290000) PPP IPCP Receive Configuration ACK |
15:50:56, 24 Aug. | ( 4714.040000) PPP IPCP Send Configuration ACK |
15:50:56, 24 Aug. | ( 4714.040000) PPP IPCP Receive Configuration Request |
15:50:56, 24 Aug. | ( 4713.820000) PPP IPCP Send Configuration ACK |
15:50:56, 24 Aug. | ( 4713.820000) PPP IPCP Receive Configuration Request |
15:50:55, 24 Aug. | ( 4713.430000) PPP IPCP Send Configuration Request |
15:50:55, 24 Aug. | ( 4713.420000) PPP IPCP Receive Configuration NAK |
15:50:53, 24 Aug. | ( 4711.400000) PPP IPCP Send Configuration ACK |
15:50:53, 24 Aug. | ( 4711.400000) PPP IPCP Receive Configuration Request |
15:50:50, 24 Aug. | ( 4708.560000) PPP IPCP Send Configuration Request |
15:50:50, 24 Aug. | ( 4708.560000) WAN operating mode is Ethernet |
15:50:50, 24 Aug. | ( 4708.560000) Last WAN operating mode was Ethernet |
15:50:49, 24 Aug. | ( 4706.910000) PPPoE is up |
15:50:49, 24 Aug. | ( 4706.900000) CHAP authentication successful |
15:50:49, 24 Aug. | ( 4706.760000) CHAP Receive Challenge |
15:50:49, 24 Aug. | ( 4706.760000) Starting CHAP authentication with peer |
15:50:49, 24 Aug. | ( 4706.760000) PPP LCP Receive Configuration ACK |
15:50:49, 24 Aug. | ( 4706.750000) PPP LCP Send Configuration Request |
15:50:49, 24 Aug. | ( 4706.750000) PPP LCP Receive Configuration Reject |
15:50:48, 24 Aug. | ( 4706.620000) PPP LCP Send Configuration ACK |
15:50:48, 24 Aug. | ( 4706.620000) PPP LCP Receive Configuration Request |
15:50:48, 24 Aug. | ( 4706.620000) PPP LCP Send Configuration Request |
15:50:06, 24 Aug. | ( 4664.420000) CWMP: session closed due to error: Could not resolve host |
15:50:06, 24 Aug. | ( 4664.080000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username |
15:50:06, 24 Aug. | ( 4664.070000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
15:49:34, 24 Aug. | ( 4632.100000) CWMP: session closed due to error: Could not resolve host |
15:49:32, 24 Aug. | ( 4630.380000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username |
15:49:32, 24 Aug. | ( 4630.380000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
15:49:30, 24 Aug. | ( 4628.390000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
15:49:28, 24 Aug. | ( 4625.960000) PPPoE is down after 75 minutes uptime [Disconnected] |
15:49:24, 24 Aug. | ( 4622.070000) PPP LCP Send Termination Request [Peer not responding] |
