Dubstar
Message 11 of 18
Re: HH4 disconnects & slow internet
Ok here is the log
1. Best Effort Test: -provides background information.
 Download  Speed
 1.22 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.22 Mbps
 For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
 IP Profile for your line is - 1.24 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.34 Mbps
0 Mbps0.45 Mbps
Upload speed achieved during the test was - 0.34Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
imjolly
Message 12 of 18
Can you also post the 2 lines of stats from the logs showing connection speed and noise margin
Dubstar
Message 13 of 18
21:23:22, 22 Dec. BLOCKED 1 more packets (because of First packet is Invalid)
21:23:21, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62854-​>216.58.208.67:443 on ppp0)
21:22:45, 22 Dec. BLOCKED 2 more packets (because of First packet is Invalid)
21:22:43, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62954-​>185.31.128.208:80 on ppp0)
21:22:43, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62997-​>185.31.128.208:443 on ppp0)
21:22:42, 22 Dec. BLOCKED 1 more packets (because of First packet is Invalid)
21:22:41, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62960-​>199.38.164.47:80 on ppp0)
21:20:49, 22 Dec. BLOCKED 1 more packets (because of Remote administration)
21:20:48, 22 Dec. IN: BLOCK [16] Remote administration (TCP 141.212.122.162:35781-​>86.130.9.170:443 on ppp0)
21:17:05, 22 Dec. BLOCKED 1 more packets (because of First packet is Invalid)
21:17:04, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:60762-​>74.125.133.109:993 on ppp0)
21:17:00, 22 Dec. BLOCKED 1 more packets (because of First packet is Invalid)
21:16:59, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:60762-​>74.125.133.109:993 on ppp0)
21:16:57, 22 Dec. BLOCKED 2 more packets (because of First packet is Invalid)
21:16:56, 22 Dec. BLOCKED 1 more packets (because of First packet is Invalid)
21:16:54, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:60762-​>74.125.133.109:993 on ppp0)
21:16:54, 22 Dec. BLOCKED 4 more packets (because of First packet is Invalid)
21:16:53, 22 Dec. BLOCKED 1 more packets (because of First packet is Invalid)
21:16:52, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:60762-​>74.125.133.109:993 on ppp0)
21:15:13, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:60754-​>157.55.236.84:443 on ppp0)
21:15:07, 22 Dec. BLOCKED 1 more packets (because of First packet is Invalid)
21:15:06, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:60754-​>157.55.236.84:443 on ppp0)
21:05:52, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:60751-​>157.56.124.210:443 on ppp0)
21:05:46, 22 Dec. BLOCKED 1 more packets (because of First packet is Invalid)
21:05:45, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:60751-​>157.56.124.210:443 on ppp0)
21:04:12, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.66:49818-​>17.110.229.151:443 on ppp0)
21:04:11, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62494-​>185.31.128.208:443 on ppp0)
21:04:10, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62493-​>185.31.128.208:443 on ppp0)
21:04:04, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.66:49818-​>17.110.229.151:443 on ppp0)
21:04:02, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62452-​>199.38.164.47:80 on ppp0)
21:04:02, 22 Dec. BLOCKED 1 more packets (because of First packet is Invalid)
21:04:02, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62441-​>185.31.128.208:80 on ppp0)
21:03:58, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.66:49818-​>17.110.229.151:443 on ppp0)
21:03:16, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.70:50237-​>17.143.163.150:5223 on ppp0)
21:03:16, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62217-​>185.31.128.208:80 on ppp0)
21:03:13, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.70:50237-​>17.143.163.150:5223 on ppp0)
21:03:12, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.64:62200-​>185.31.128.208:80 on ppp0)
21:03:09, 22 Dec. OUT: BLOCK [65] First packet is Invalid (TCP 192.168.1.70:50237-​>17.143.163.150:5223 on ppp0)
20:59:58, 22 Dec. IN: BLOCK [16] Remote administration (TCP 183.60.48.25:32204-​>86.130.9.170:22 on ppp0)
20:59:50, 22 Dec. (21575.620000) New GUI session from IP 192.168.1.64
20:59:28, 22 Dec. (21553.760000) WAN operating mode is DSL
20:59:28, 22 Dec. (21553.760000) Last WAN operating mode was DSL
20:59:28, 22 Dec. (21553.740000) PPPoA is up -​ VPI: 0, VCI:38
20:59:28, 22 Dec. (21553.730000) PPP IPCP Receive Configuration ACK
20:59:28, 22 Dec. (21553.710000) PPP IPCP Send Configuration Request
20:59:28, 22 Dec. (21553.700000) PPP IPCP Receive Configuration NAK
20:59:28, 22 Dec. (21553.700000) PPP IPCP Send Configuration ACK
20:59:28, 22 Dec. (21553.700000) PPP IPCP Receive Configuration Request
Dubstar
Message 14 of 18
Apologies  forgot to post the requested info
I just had a disconnection earlier. I left it alone without resetting or restart, and it came back. Speed however, still quite slow.
20:59:28, 22 Dec.(21553.580000) PPP LCP Send Configuration ACK
20:59:28, 22 Dec.(21553.580000) PPP LCP Receive Configuration Request
20:59:28, 22 Dec.(21553.530000) PPP LCP Receive Configuration ACK
20:59:28, 22 Dec.(21553.510000) PPP LCP Send Configuration Request
20:59:25, 22 Dec.(21550.530000) PPP LCP Receive Configuration ACK
20:59:25, 22 Dec.(21550.510000) PPP LCP Send Configuration Request
20:59:25, 22 Dec.(21550.510000) PPP LCP Receive Configuration Reject
20:59:25, 22 Dec.(21550.210000) PPP LCP Send Configuration Request
20:59:23, 22 Dec.(21548.200000) DSL is up
20:59:23, 22 Dec.(21547.990000) DSL noise margin: 9.00 dB upstream, 9.10 dB downstream
20:59:23, 22 Dec.(21547.920000) DSL line rate: 448 Kbps upstream, 1408 Kbps downstream
20:58:50, 22 Dec.(21515.270000) DSL is down after 59 minutes uptime
20:58:49, 22 Dec.(21514.810000) PPPoA is down after 59 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
20:58:48, 22 Dec.(21513.730000) PPP LCP Send Termination Request [User request]
imjolly
Message 15 of 18
Even after the reset speed and noise margin same as before
Dubstar
Message 16 of 18
What do you think though ? Is it normal ? Disconnections, terrible speed. Can barely browse the web without it timing out. I bought a new HH4 today in hope it would resolve the problem, guess I was wrong. Am out of ideas. Have called BT lots this week, they said they would call me 3pm this afternoon, and they didn't. What does one do????
imjolly
Message 17 of 18
are you currently using the test socket with a new filter?
Dubstar
Message 18 of 18
Using normal socket now. Tried new filter that came with HH4 with test socket. Same.
Todays speed test 0.37 upload speed 0.3
