TheSubmit
Message 11 of 24
Re: HH4 has suddenly slowed down and always dropping connection
TEST 2 RESULTS: test2.png
TheSubmit
Message 12 of 24
I am on the Tap3 Test Config, where do I find DSL username and password on HH4? please#
Thank you for your help thus far
Keith_Beddoe
Message 13 of 24
Tap3 test not needed.
Keith_Beddoe
Message 14 of 24
Did you check for noise on your phone line, as this has been asked a few times now?
Dial 17070 and select option 2, there should be no noise between the announcements.
licquorice
Message 15 of 24
You need an engineer visit to resolve the problem, report it to customer services 0800 1114567 that your speed is far below acceptable.
TheSubmit
Message 16 of 24
I have done the test and it is very quiet, but normally when I am making calls and such there is crackling and people tell me they cannot hear me properly
licquorice
Message 17 of 24
There's the problem then, until the noisy line is fixed your broadband won't improve. Is there a difference in the quiet line test when connected to the test socket and when connected normally?
TheSubmit
Message 18 of 24
Now that I am connected to the test socket it is fine as I am on the phone to BT right now booking an engineer, but when its normal there is crackling noises
licquorice
Message 19 of 24
In that case the problem is in your internal wiring and you will be charged for an engineer visit, best to cancel. You need to investigate your internal wiring.
TheSubmit
Message 20 of 24
Investigate my internal wiring? what do you mean by that please, the engineer has been booked I will cancel then
