licquorice
Message 21 of 24
Re: HH4 has suddenly slowed down and always dropping connection
When you remove the front faceplate you are disconnecting all your extension wiring, if there is noise when the extensions are connected but not from the test socket when they are not, it indicates there is a problem with your extension wiring that is causing the noise. Internal wiring is your responsibility not BT's.
TheSubmit
Message 22 of 24
OK I understand, thank you for all your help but there is not much I can do but to call an engineer in thanks for all your help as I have learned quite a lot today Smiley Happy
TheSubmit
Message 23 of 24
Thanks for the help guys, engineer came round and indeed it was the interrnal wiriring at my home that was the problem and it has been fixed, now acheiving full speeds Smiley Very Happy
licquorice
Message 24 of 24
Glad you got it fixed but expect a £130 bill for the privilege.
