trapdoor
Expert
Message 1 of 21
HH4A firmware update today - to 4.7.5.1.83.8.130.1.17
Just had a HH4 reboot on me whilst recording something on one of the IP multicast channels - then seemed to go mental when it came back up by flooding my LAN with IGMP packets (seen on my gig hubs with all port lights flashing in sequence) which for some reason made my Apple AE/TimeCapsule that I use as a WiFi AP fall over Smiley Surprised
So did a power off reboot and it all came back up OK - checked the log and:
11:40:15, 04 Dec.(3995791.650000) CWMP: session completed successfully
11:40:14, 04 Dec.(3995790.040000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
11:40:11, 04 Dec.(3995787.220000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
11:40:11, 04 Dec.(3995787.210000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE'
11:40:10, 04 Dec.(3995786.820000) CWMP: Initializing transaction for event code M Download
11:40:10, 04 Dec.(3995786.820000) transfer completed successfully
11:40:10, 04 Dec.(3995786.570000) CWMP: Download status=OK
11:39:29, 04 Dec.(3995745.980000) CWMP: session completed successfully
11:39:29, 04 Dec.(3995745.750000) CWMP: Download file, FileType=1, FileName=prod_sec.enc.rms, Username=, CommandKey=1275933521
11:39:29, 04 Dec.(3995745.460000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
11:39:26, 04 Dec.(3995742.890000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
11:39:26, 04 Dec.(3995742.890000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,4 VALUE CHANGE'
11:39:26, 04 Dec.(3995742.500000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
So we have had an update and it decided to reboot on me, not whilst I was out and nothing happening, but whilst I was recording something - The log just shows normal stuff and then shows a reboot.
Can't see any info about an update on the forum and wondered if anyone else had noticed this, and what this is supposed to fix/improve? My HH4 now shows:
BT Home Hub 4 (Type A) | Software version 4.7.5.1.83.8.130.1.17 | Last updated 04/12/13
I do wish though that BT wouldn't just push stuff out without due recourse to the subscriber - most other suppliers will tell you about the update, give a brief synopsis of what is in the update and check whether you want to install it now or later.
20 REPLIES 20
19nbg71
Expert
Message 2 of 21
Re: HH4A firmware update today - to 4.7.5.1.83.8.130.1.17
i hope its opened the hub up more for diagnostics Smiley Happy
i'm still on the old one still
BT Home Hub 4 (Type A) | Software version 4.7.5.1.83.8.130.1.10 | Last updated 11/09/13 Smiley Sad
Checked2013
Expert
Message 3 of 21
@19nbg71 I dout it would do that as the line stats come from the white openreach modem and not the HomeHub4
One thing that I have noticed that has been fixed is the Home Network now displays correctly under the advanced settings menu.
19nbg71
Expert
Message 4 of 21
i know the white modem is locked, but i just hoped the hub could send commands to and from the modem for stats Smiley Happy
Checked2013
Expert
Message 5 of 21
I think you've answered your own question as the HomeHub can't do that because the modem is locked.
trapdoor
Expert
Message 6 of 21
Hmmm ... not convinced it's 100% working as doing a refresh seems to 'move' devices around. I only have my Vision+ box plugged intp port 1 but clicking refresh seems to get it to show devices that are on a Gig hub plugged into port 4  appearing on port 1, and then do another refresh and the disappear altogether.
So, whilst it seems a bit better, it ain't working correctly still.
hippey
Expert
Message 7 of 21
I had even more of a nightmare!
My 2.4G fell over and died! Ended up doing a factory reset, no idea why it died but it wasn't broadcasting at all despite the HH thinking it was. The 5G was unaffected.
My BTV box wasn't too happy about it either, although with the reset seems to have settled back down to behave. However doing the factory reset has taken down my BTWifi Zone.
DS
Distinguished Guru
Message 8 of 21
Found this thread* whilst doing some research/tests so thought I'd add my bit
I can only see that the home network section has been altered to show a (rough drawn?) HH4 and the page layout has been tweaked - is there a need to show laptop images for ALL devices?. This still needs another tweak as my MAC addresses overlap (see red boxes)
* I no longer 'lurk' on these forums. I'll more than likely not reply to any other contributions on this subject either
-+-No longer a forum member-+-
Travelusa
Expert
Message 9 of 21
Strange used ethernet cable from my laptop with 1gb port to the hub 1gb port
new software show 100mb cannot they get that right
trapdoor
Expert
Message 10 of 21
Sure it's definitely running at 1 gig? Not limited to 100meg in software is it (ie not set to run at 1g)? My hub correctly shows port 4 as running at 1 gig with an 8-port hub plugged in, and everything running at 1 gig plugged into the hub is correctly identified.
