AlanH1
Message 1 of 5
HH5 Port Forwarding issues
Hi guys,
I've been trying for a couple of weeks now to try and forward a port from my HH5 but to no avail. What seems like such a simple task has got me puzzled. I've watched videos on YouTube and prowled loads of forums but still can't seem to do anything.
I'm using a static ip address on the PC I'm trying to forward to and I've switched between upnp on/off but nothing and also tried Dhcp on/off but again no progress. To see if the port is open i go into cmd on my pc and type "netstat -a". The port in question is UDP 3290 - If that makes any difference. I'm fairly new to this so happy to follow any advice anyone has.
Thanks in advance
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: HH5 Port Forwarding issues
This page should help.
Port forwarding problems
umbr3lla
Message 3 of 5
I have the same problem.
I've opened up some ports that I wish to use in the advanced settings then under port fowarding under firewall.
I've set the ports I want to open up and assigned it to the devices ip address from the drop down list.  However when I do a port scan it doesn't show that the port is open.  I have rebooted the router and that made no difference.
Also what I noticed when I try to ping my real world IP address the pings are unsuccessful.  I disabled the firewall on the HH5 but again no difference.
I am using BT Home Hub 5 - Software version 4.7.5.1.83.8.204 (Type A).
Really confused.  Any help would be appreciated as I cannot access some devices from outside the network.
licquorice
Message 4 of 5
Have you disabled UPnP?
Keith_Beddoe
Message 5 of 5
Did you check that you are not on CG-NAT, as described on my port forwarding link?
