Kazzablanca
Message 1 of 5
HH5 Power Supply type A or B:is there a difference re use.
Hi
Just a general question: I have a HH5 TypeB with the a type B power supply. However, I also have a spare HH4/5 type A power supply.
My question is; would that Type A power supply work with the Home Hub5 TypeB, re emergencies if the type B power supply stopped working?
Cheers
K
4 REPLIES 4
john46
Message 2 of 5
Re: HH5 Power Supply type A or B:is there a difference re use.
No they are different
Kazzablanca
Message 3 of 5
Thanks for that.
I presume therefore, if the power supply on the HH5 goes then you can buy a replacement easily enough. I could not find one on the BT store pages.
I always like a back-up, even though I use a dedicated power socket. Ebay will be my friend unless BT supply as a matter of course re the contract you have with them?
imjolly
Message 4 of 5
more likely report it as a hub fault and get a replacement hub
Devon_Dave
Distinguished Guru
Message 5 of 5
or visit the well known internet auction site and get a spare hub as well.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
