trevrobwhite
Message 1 of 5
HH5 Reducing Static Noise
Hi all,
I have the HH5, this is the second box I've had as the first developed a fault.
One thing I find really annoying is that during data transfer the HH emits a very high pitched clicking noise. If your watching streamed TV this is extremely annoying. (Both boxes do this)
I've read it's something to do with the power switching inside the box and was wondering if there is any way to reduce this? Turing off/changing frequency etc.
My sky router never made a sound.
Many thanks in advance.
4 REPLIES 4
imjolly
Message 2 of 5
Re: HH5 Reducing Static Noise
Really strange both your hands have the same noise. It should be quiet so I would go to customer services and see about another replacement
trevrobwhite
Message 3 of 5
It's not really loud more of a high pressure noise. I take it the no should be silent then?
imjolly
Message 4 of 5
I don't have any noise from my hh5a when transferring data
is it the hub or possible the power supply
trevrobwhite
Message 5 of 5
No it's definitely the hub. I will get on to BT I think see if they can swap it out. Many thanks.
