DanMax89
Message 1 of 7
HH5 Restart - Logs say Power Button pressed?
Hi all,
Can anyone tell me why my HH5 has restarted after 10 or so days of uptime? The DLM was reset at the exchange 10 days ago so I am unsure if this is part of the process. Speeds don't appear to have changed and I'm still sycning at max for infinity 2. I'm wondering why there's a System start Button press (PowerButton) event in there as I haven't touched the hub so as to avoid upsetting DLM. Logs from time of restart below.
08:47:28, 27 May.Booting firmware v0.07.05.0A13-BT (Thu Oct 15 14:28:46 2015)
08:47:28, 27 May.System start Button press (PowerButton)
08:47:24, 27 May.5G WiFi scan(Reason:boot)
08:47:12, 27 May.System up
08:47:07, 27 May.Wire Lan Port 3 up
08:46:56, 27 May.2.4G WPS feature enabled
08:46:56, 27 May.2.4G WPA2 mode selected
08:46:56, 27 May.2.4G WiFi UP
08:46:56, 27 May.5G WPS feature disabled
08:46:56, 27 May.5G WPA2 mode selected
08:46:56, 27 May.5G WiFi UP
08:46:55, 27 May.IPv6 Service: DHCP Server stop
08:46:55, 27 May.IPv6 Service: RA Server stop
6 REPLIES 6
DanMax89
Message 2 of 7
Re: HH5 Restart - Logs say Power Button pressed?
Updating with helpdesk stats and expanded logs.. noticed a 'CWMP: Set Parameter by TR069 Success' half an hour before reboot.
1. Product Name: HomeHub5
2. Serial number: +076286+1549002260
3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 10/3/2016
4. Board version: 01
5. VDSL uptime: 1 days, 06:12:45
6. Data Rate: 20000 / 79987
7. Maximum Data Rate: 28128 / 87672
8. Noise Margin: 10.1 / 8.1
9. Line Attenuation: 14.6 / 15.7
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 85.0 MB / 685.0 MB
12. Broadband username: bthomehub@btbroadband.com
08:15:44, 27 May.CWMP: HDM socket closed successfully.
08:15:44, 27 May.CWMP: HTTP authentication success from pbthdm.x.x.x
08:15:44, 27 May.CWMP: HDM socket opened successfully.
08:15:44, 27 May.CWMP: Set Parameter by TR069 Success.
08:15:41, 27 May.CWMP: HDM socket closed successfully.
08:15:40, 27 May.CWMP: HTTP authentication success from pbthdm.x.x.x
08:15:40, 27 May.CWMP: HDM socket opened successfully.
08:15:40, 27 May.CWMP: session completed successfully
08:15:40, 27 May.CWMP: HDM socket closed successfully.
08:15:39, 27 May.CWMP: HDM socket opened successfully.
08:15:38, 27 May.CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
08:15:38, 27 May.CWMP: Session start now, server: pbthdm.x.x.x, Event code:
08:15:38, 27 May.CWMP: Initializing transaction for event code 6 CONNECTION REQUEST
08:15:31, 27 May.CWMP: HDM socket closed successfully.
08:15:31, 27 May.CWMP: HTTP authentication success from pbthdm.x.x.x
08:15:30, 27 May.CWMP: HDM socket opened successfully.
08:15:30, 27 May.CWMP: session completed successfully
08:15:30, 27 May.CWMP: HDM socket closed successfully.
08:15:30, 27 May.CWMP: HTTP authentication success from pbthdm.x.x.x
08:15:29, 27 May.CWMP: HDM socket opened successfully.
08:15:28, 27 May.CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
08:15:28, 27 May.CWMP: Session start now, server: pbthdm.x.x.x, Event code:
08:15:28, 27 May.CWMP: Initializing transaction for event code 2 PERIODIC
smf22
Recognised Expert
Message 3 of 7
I've noticed the HH5B shows button press for a number of reboot events. I've seen it when my hub crashed and restarted, and when the hub is restarted by BT every 14 days.
As far as whether the restart was related to the CWMP event, I don't think we'll know. A reboot is one of the methods within CWMP (section A.3.2.9 of TR-069), but as there's no details in the log relating to the parameter that was set, it'd be a guess to say that's what caused the reboot.
DanMax89
Message 4 of 7
The Hub is restarted every 14 days? This is news to me.
imjolly
Message 5 of 7
Spoiler
The 14 days reboot is more associated with the hh5a not 5b and is caused by the DLM. It is more of an inconvenience than a problem as speed and noise margin are just the same before and after restart
smf22
Recognised Expert
Message 6 of 7
I've been seeing it on my HH5B with the v0.07.05.0A13-BT firmware. The hub was installed on 29-Mar and then rebooted every 14-days up to 11-May.
16:36:28, 11 May.	System start Button press (PowerButton)
16:36:11, 11 May.	System up
16:25:51, 27 Apr.	System start Button press (PowerButton)
16:25:34, 27 Apr.	System up
16:18:01, 13 Apr.	System start Button press (PowerButton)
16:17:42, 13 Apr.	System up
16:11:16, 29 Mar.	System start Button press (PowerButton)
16:10:59, 29 Mar.	System up
The above cycle has been broken now as we've had a couple of power outages.
DanMax89
Message 7 of 7
Same thing again last night, can someone advise the cause of this? Again, sync speeds have not changed.
05:21:41, 29 May.5G WiFi auto selected channel 36 Bandwidth:80M(Reason:boot)
05:21:35, 29 May.5G WiFi scan(Reason:boot)
05:21:33, 29 May.2.4G WiFi auto selected channel 1 Bandwidth:20M(Reason:boot)
05:21:33, 29 May.NTP synchronization start
05:21:31, 29 May.WAN connection PTM connected
05:21:30, 29 May.PPP IPCP Receive Configuration ACK
05:21:30, 29 May.PPP IPCP Send Configuration Request
05:21:30, 29 May.PPP IPCP Receive Configuration NAK
05:21:30, 29 May.PPP IPCP Send Configuration ACK
05:21:30, 29 May.PPP IPCP Receive Configuration Request
05:21:30, 29 May.PPP CHAP Receive success : authentication successful
05:21:29, 29 May.PPP CHAP Receive Challenge
05:21:29, 29 May.PPP LCP Receive Configuration ACK
05:21:29, 29 May.PPP LCP Send Configuration ACK
05:21:29, 29 May.PPP LCP Receive Configuration Request
05:21:29, 29 May.PPP LCP Send Configuration Request
05:21:28, 29 May.2.4G WiFi scan(Reason:boot)
05:21:15, 29 May.2.4G WiFi auto selected channel 1 Bandwidth:20M(Reason:boot)
05:21:15, 29 May.DSL Link Up: Down Rate=79987Kbps, Up Rate=20000Kbps; SNR Margin Down=8.1dB, Up=10.0dB
05:21:05, 29 May.2.4G WiFi scan(Reason:boot)
05:21:05, 29 May.5G WiFi auto selected channel 36 Bandwidth:80M(Reason:boot)
05:20:58, 29 May.5G WiFi scan(Reason:boot)
05:20:47, 29 May.Booting firmware v0.07.05.0A13-BT (Thu Oct 15 14:28:46 2015)
05:20:47, 29 May.System start Button press (PowerButton)
05:20:43, 29 May.5G WiFi auto selected channel 36 Bandwidth:80M(Reason:boot)
05:20:38, 29 May.5G WiFi scan(Reason:boot)
05:20:31, 29 May.System up
05:20:25, 29 May.Wire Lan Port 3 up
05:20:14, 29 May.2.4G WPS feature enabled
05:20:14, 29 May.2.4G WPA2 mode selected
05:20:14, 29 May.2.4G WiFi UP
05:20:14, 29 May.5G WPS feature disabled
05:20:14, 29 May.5G WPA2 mode selected
05:20:14, 29 May.5G WiFi UP
05:20:13, 29 May.IPv6 Service: DHCP Server stop
05:20:13, 29 May.IPv6 Service: RA Server stop
