@readjono wrote:
Link didnt work on my mobile but it looks filtered. Internet on top and then a phone socket.
Try again, as the night time domain restrictions were in force on my public webserver, I have removed them.
I suspect that is number 6, is that correct?
If it is, then they do have a habit of failing, sometimes for no reason.
@readjono wrote:
Yes number 6. We tried the test socket is that still an issue?
Yes it can be.
Can you remove both parts of the NTE, there are a couple of screws which hold the back piece on?
Behind that, there will be the main test socket, can you try a microfilter plugged into that socket, with the home hub and phone in the microfilter?
Do you have any other sockets or extension phone wiring?
@readjono wrote:
Just unscrewed it
Applied a microfilter and put in the phone and internet.
It did the usual blue green and orange again without touching it
Do you have any other sockets or extension wiring?
@readjono wrote:
Yes this is our only socket, this has been our setup for the last five or six years
Thanks.
Well I an going to make a guess that your problem is the same as what is described in this thread, as the timing seems the same.
I suspect the home hub is trying to connect and failing at the PPP layer, and the whole thing starts again.
Take a read of that thread, and see if it ties up.
And another one https://community.bt.com/t5/BT-Infinity-Speed-Connection/No-Broadband-for-Xmas-or-New-Year-BT-seemin...
This is a a shorter thread with the same issue.
I would like to add that i also i have the exactly same problem with home hub 5 , orange light constantly on.
