readjono
Message 11 of 19
Re: HH5 has stopped working - orange light - tried two routers
Link didnt work on my mobile but it looks filtered. Internet on top and then a phone socket.
Keith_Beddoe
Message 12 of 19
Try again, as the night time domain restrictions were in force on my public webserver, I have removed them.
I suspect that is number 6, is that correct?
If it is, then they do have a habit of failing, sometimes for no reason.
readjono
Message 13 of 19
Yes number 6. We tried the test socket is that still an issue?
Keith_Beddoe
Message 14 of 19
Yes it can be.
Can you remove both parts of the NTE, there are a couple of screws which hold the back piece on?
Behind that, there will be the main test socket, can you try a microfilter plugged into that socket, with the home hub and phone in the microfilter?
Do you have any other sockets or extension phone wiring?
readjono
Message 15 of 19
Just unscrewed it
Applied a microfilter and put in the phone and internet.
It did the usual blue green and orange again without touching it
Keith_Beddoe
Message 16 of 19
@readjono wrote:
Just unscrewed it
Do you have any other sockets or extension wiring?
readjono
Message 17 of 19
Yes this is our only socket, this has been our setup for the last five or six years
Keith_Beddoe
Message 18 of 19
Thanks.
Well I an going to make a guess that your problem is the same as what is described in this thread, as the timing seems the same.
https://community.bt.com/t5/BT-Infinity-Speed-Connection/BT-Infinity-2-WAN-Connection-Dead/td-p/1805...
I suspect the home hub is trying to connect and failing at the PPP layer, and the whole thing starts again.
Take a read of that thread, and see if it ties up.
And another one https://community.bt.com/t5/BT-Infinity-Speed-Connection/No-Broadband-for-Xmas-or-New-Year-BT-seemin...
This is a a shorter thread with the same issue.
mrial
Message 19 of 19
I would like to add that i also i have the exactly same problem with home hub 5 , orange light constantly on.
https://community.bt.com/t5/BT-Infinity-Speed-Connection/no-internet-since-23rd-december/td-p/180736...
