Fatboyslick
Message 1 of 2
HH5 on Infinity started to drop out twice an evening (Orange light)
HI
Wanted to post here before risking the dreaded long call to a foreign tech support but my Broadband has started dropping out each evening.
It literally drops for 2 mins on two occaisions each evening.
So, the light will be blue but my devices won't connect to the net...I literally watch the Home Hub for a minute waiting for the light to start flashing orange....which it does and then reconnects.
Ive no idea why this is.
Any thoughts
1 REPLY 1
john46
Message 2 of 2
Re: HH5 on Infinity started to drop out twice an evening (Orange light)
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
