adamd
Message 1 of 9
HH5 to HH3
Hi
I have changed from HH5 to HH3 and now I cant connect to internet.
I know the HH3 was working as it was working in the house that I got it from.
Obviously HH5 was working previously and I thought i would just be able to plug in HH3.
I havent tried swapping them back yet as I gave HH5 to a mate. Too complicated to explain why!
Any ideas? Does HH5 have built in adsl filter and HH3 not?
8 REPLIES 8
john46
Message 2 of 9
Re: HH5 to HH3
no there are no filters in any hub are you using normal broadband or infinity
adamd
Message 3 of 9
Re: HH5 to HH3
Thanks John.
Normal broadband.
I have just checked my socket type and it has got a built in filter.
Phone is ok.
Strange that hh3 doesn't work when hh5 worked three days ago.
john46
Message 4 of 9
Re: HH5 to HH3
are you having problems with wireless or a wired connection
adamd
Message 5 of 9
Re: HH5 to HH3
I am just getting flashing purple / orange light on router so it is not connecting.
john46
Message 6 of 9
Re: HH5 to HH3
check the phone to hub cable m then if you still have problems try a factory reset
adamd
Message 7 of 9
Re: HH5 to HH3
ok. Did factory reset today. Not checked cable. will try that.
imjolly
Message 8 of 9
Re: HH5 to HH3
Have you tried connecting a filter to the test socket and then hub to filter and see if that get a connection
adamd
Message 9 of 9
Re: HH5 to HH3
Good idea. Will try that tomorrow.
