dave3d
Message 1 of 13
HH6 limited to 3 hosts
This is my first post so show me some patience.
I have the new BT smart hub or home hub 6 which I have been slowly configuring. I previously had home hubs 2, 4 and 5, so I can find my way around it to a certain extent.
I pay No-IP for 20 host addresses and I have been configuring the router and ports to allow access to computers on my home network. I have a mixture of W10, W7, XP and several raspberry pi's some with cameras.
However the new homehub says maximum 3 hosts allowed in other words I cannot access more than 3 devices through the router using DNS? My previous router Homehub 5 had no such restriction.
I have tried all the settings. I don't wish to put a Dynamic Update Client (DUC) on each machine. Not even sure if that would work.
12 REPLIES 12
licquorice
Message 2 of 13
Re: HH6 limited to 3 hosts
I suggest you revert to your HH5, the HH6 is a backward step in many respects.
dave3d
Message 3 of 13
Thanks.
I have now switched back to HH5 and have about 12 hosts set up on it.
dave3d
Message 4 of 13
As a matter of interest are there any advantages that HH6 has over previous versions?
Maybe the GUI but other than that I can't see anything that is an improvement. Quite the contrary.
Keith_Beddoe
Message 5 of 13
Perhaps the advantage of expensive marketing Smiley Wink
The lack of wireless channel selection is a disadvantage.
licquorice
Message 6 of 13
Allegedly, the wifi is supposed to be an improvement but from comments on the forum I don't believe it is. The wifi is certainly hobbled, as it is now only possible to manually select 3 of the 13 channels available in the 2.4Ghz band. As usual a triumph of style over content, as long as it it looks pretty the designers are happy!!
Keith_Beddoe
Message 7 of 13
Style over substance ?
The WiFi channel limitation, makes no sense at all, what logic were they applying?
imjolly
Message 8 of 13
as a user of a HH6 I can confirm that the wifi gives better coverage than the hh5 - there have been other posts saying the same thing so not specific to my 'specialSmiley Very Happy' hh6
Dan-O
BT Devices Expert
BT Devices Expert
Message 9 of 13
1, 6 and 11 are the only non-overlapping Wi-Fi channels (with the exception of 12/13 but these are rarely used because they're not supported in the USA so some devices have problems).
Using channels in between these can cause issues as channel 2 will interfere with both channel 1 and channel 6 for example. And channel selection algorithms may not detect the interfere if they simply look for other devices on the exact same channel.
Channel 1 uses none of the same frequency as Channel 6 and Channel 11 uses none of the same as Channel 6. This is because 2.4GHz Wi-Fi channels are split into 5MHz segments and the normal mode of operation is 20MHz (which will take up 4 5MHz chunks).
Keith_Beddoe
Message 10 of 13
Those channels are overlapped by signals from other routers. The problem with only three channels is if you are in a built up area, those three channels are already occupied by other home hubs, so you end up with home hubs playing leapfrog, and disconnecting devices in the process.
I use a different router, in a built up area, and the only clear channels are channel 5,channel 9 and channel 13. The rest are occupied by home hubs, Sky routers (which also use 1,6 and 11), and Virgin Media hubs, which seem to occupy two channels at a time Smiley Sad
