spec_d
Message 1 of 2
HHub reporting high usage overnight with nothing on
Looks like my HHub reset overnight (1 am ish) and has managed to use 26571 Mb in 7 hours!!
This is with nothing left on overnight (double checked) and wireless permanently disabled.
Are the HHub stats known to be inaccurate?
I've reset the HHub again and the usage stats have gone back to zero.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: HHub reporting high usage overnight with nothing on
Hi Spec_d,
Thanks for posting. I'm sorry for the delay in getting back to you. This sounds like a temporary glitch but I can check it for you if you want. Drop me an email with your account details and a link to this thread for reference. You'll find the address in my profile.
Cheers
David
