robertwint
Message 1 of 2
HP Printer keeps losing connection to BT Mini Home Hotspot 500 Kit
I have a Home Hub thats extended using a BT Mini Home Hotspot 500 Kit, I've paired them so they use the same SSID. Since I've done this my HP Photosmart 6520 wireless printer drops and doens't connect back to the SSID, it may be that the printer see's two routers with the same name and is confused? One suggestion was to change the 500 Hotspot channel, does anyone know how I get into it to adminster this?
Thanks in advance.
1 REPLY 1
licquorice
Message 2 of 2
Re: HP Printer keeps losing connection to BT Mini Home Hotspot 500 Kit
Enter the IP address of the extender in your browser to login, password is on the plastic card at the rear of the extender.
Edit: It would probably be better to give it a different SSID, that is more likely to confuse the printer than channel.
