Lucifity
Message 1 of 12
HTTP hanging?
Recently been experiencing a problem, my web browsing sometimes gets stuck, I can't browse to any website however I can use programs like Skype, etc.
11 REPLIES 11
sjtp
Guru
Message 2 of 12
Re: HTTP hanging?
Could be a browser problem. Try with all plugins disabled, and try a different browser.
Could be a dns issue. Try http://82.165.127.190/ . That won't give you a useful page, just a 404 not found page, but should do an HTTP turnaround that does not require DNS. If it works, that points to dns as the problem.
infinidim
Expert
Message 3 of 12
Re: HTTP hanging?
Completely agree with sjtp.
Infinidim
Megadodo Publications
Ursa Minor Beta
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side
If the the reply answers your question then please mark as ’Mark as Accepted Solution’
legitimise_sailing
Distinguished Expert
Message 4 of 12
Re: HTTP hanging?
It would be better to try http://212.58.253.67 to go to the BBC as that should yield a proper result
To say thanks for a helpful answer, please click the white star
sjtp
Guru
Message 5 of 12
Re: HTTP hanging?
I chose a webpage that did not have any references to other pages.
With a 'real' page, there will be lots of references, some of which will be relative and not require dns lookup, but there may well be others to external domain that require further dns lookup. That bbc page has lots of references to static.bbci.co.uk that would require dns resolution.
Lucifity
Message 6 of 12
Re: HTTP hanging?
It loaded the BBC homepage.
And this problem is beginning to be annoying, how can I fix it?
I didn't understand what sjtp wanted me to do exactly.. It just shows a 404 page and that's it
I tried to do a dns flush but nothing solved.
john46
Message 7 of 12
Re: HTTP hanging?
have you tried another browser?
Lucifity
Message 8 of 12
Re: HTTP hanging?
Yes, I tried another answer.
Lucifity
Message 9 of 12
Re: HTTP hanging?
Browser*...
john46
Message 10 of 12
Re: HTTP hanging?
web browser example internet explorer Google chrome fire fox etc.
