Message 1 of 7
HUAWEI HG612 + Asus AC68U slower than Smart Hub (6)
Hello.
On default setup (only Smart Hub) Im getting 26-28 Mb download speed. On my preffered setup (modem HG612 and router Asus AC68U) Im getting only 21-22 MB download speed. Can you tell my what is is like that? I tried changing all cable connections (RJ11's between NTE5C MK4 Master socket and HG612 and RJ45's between HG612 and Asus router). I allowed three days for line to settle but speeds didnt improve. Is there a reason for that? All speed tests done of course in wired connection.
6 REPLIES 6
Message 2 of 7
Re: HUAWEI HG612 + Asus AC68U slower than Smart Hub (6)
Probably due to different chipsets in the Hub and HG612.
Message 3 of 7
Are there any better modems that can replace old HG612 to achieve at least same speeds as Smart Hub 6?
Expert
Message 4 of 7
There are only two devices to buy new that would suit.  A Netgear DM200 and the DrayTek Vigor 130.
Look here for some information about devices that are approved by Openreach.
The Netgear is a router that needs to be configured as modem only.
https://community.bt.com/t5/Connected-Devices-Other/Problem-on-openreach-network-with-unapproved-vds...
List is at the bottom of the first link.
The alternative is to see if you can get an ECI modem from the auction site.
Message 5 of 7
Is it possible to set Smart Hub 6 as modem only and leave all the routing job to Asus AC68U router? In the past, with old Home Hubs (3, 4) I tried to do DMZ but its actually was not true DMZ. Maybe Smart Hub 6 is capable of doing that? Hearing from everywhere this is top notch, best all around, amazing, gorgeous etc.
Message 6 of 7
No, you can turn off DHCP and wireless but you can't put it in modem only mode.
Message 7 of 7
Have a look at some of the ZyXel modems (1312, 8324, 8924 etc). I have found them pretty good (though everyone's line is different) and they can be found on sites like eBay
