mellorij
Message 1 of 17
HUB 5 keeps rebooting
My HUB 5 keeps re-booting, but I can't see why, any suggestions, here is the log:
16:17:01, 22 Dec.( 41.380000) Wire Lan Port 1 up
16:17:00, 22 Dec.( 39.980000) WAN Auto-​sensing running.
16:16:56, 22 Dec.( 36.310000) The system is UP!
16:16:47, 22 Dec.( 27.660000) WPA2 mode selected
16:16:47, 22 Dec.( 27.660000) WPS enabled
16:16:46, 22 Dec.( 26.010000) WPA2 mode selected
16:16:46, 22 Dec.( 26.010000) WPS enabled
16:16:37, 22 Dec.( 17.330000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
16:15:49, 22 Dec.(394710.770000) PPP LCP Send Termination Request [User request]
16:15:47, 22 Dec.(394708.810000) The system is going DOWN for reboot.
16:10:34, 22 Dec.(394395.460000) Lease for IP 192.168.1.89 renewed by host android-​49c2a1926e843802 (MAC cc:fa:00:f3:89:12). Lease duration: 1440 min
16:10:34, 22 Dec.(394395.460000) Device connected: Hostname: android-​49c2a1926e843802 IP: 192.168.1.89 MAC: cc:fa:00:f3:89:12 Lease time: 1440 min. Link rate: 100.0 Mbps
16:10:34, 22 Dec.(394395.380000) Lease requested
16:09:40, 22 Dec.(394341.530000) Lease for IP 192.168.1.89 renewed by host android-​49c2a1926e843802 (MAC cc:fa:00:f3:89:12). Lease duration: 1440 min
16:09:40, 22 Dec.(394341.530000) Device connected: Hostname: android-​49c2a1926e843802 IP: 192.168.1.89 MAC: cc:fa:00:f3:89:12 Lease time: 1440 min. Link rate: 100.0 Mbps
16:09:40, 22 Dec.(394341.460000) Lease requested
16:08:50, 22 Dec.(394292.090000) Lease for IP 192.168.1.89 renewed by host android-​49c2a1926e843802 (MAC cc:fa:00:f3:89:12). Lease duration: 1440 min
16:08:50, 22 Dec.(394292.090000) Device connected: Hostname: android-​49c2a1926e843802 IP: 192.168.1.89 MAC: cc:fa:00:f3:89:12 Lease time: 1440 min. Link rate: 100.0 Mbps
16:08:50, 22 Dec.(394292.020000) Lease requested
15:08:25, 22 Dec.(390666.850000) Lease for IP 192.168.1.68 renewed by host Sue_Laptop (MAC a4:db:30:29:49:9e). Lease duration: 1440 min
15:08:25, 22 Dec.(390666.850000) Device connected: Hostname: Sue_Laptop IP: 192.168.1.68 MAC: a4:db:30:29:49:9e Lease time: 1440 min. Link rate: 72.2 Mbps
15:08:25, 22 Dec.(390666.780000) Lease requested
15:00:43, 22 Dec.(390204.960000) Lease for IP 192.168.1.69 renewed by host android-​a9c59e2d27435bf9 (MAC c4:43:8f:f7:b4:ef). Lease duration: 1440 min
15:00:43, 22 Dec.(390204.960000) Device connected: Hostname: android-​a9c59e2d27435bf9 IP: 192.168.1.69 MAC: c4:43:8f:f7:b4:ef Lease time: 1440 min. Link rate: 130.0 Mbps
15:00:43, 22 Dec.(390204.870000) Lease requested
16 REPLIES 16
Automan
Message 2 of 17
Re: HUB 5 keeps rebooting
If you just slect the category "Boot" you can see how often it happens
20:33:00, 28 Nov.( 15.650000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
15:58:36, 26 Nov.( 15.630000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
10:15:10, 22 Nov.( 15.670000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
15:52:52, 21 Nov.( 15.590000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
19:37:31, 20 Nov.( 16.610000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
15:41:03, 20 Nov.( 15.670000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
14:53:14, 20 Nov.( 16.670000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
14:41:12, 20 Nov.( 16.640000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
My one used to do it a lot (as you can see) and the fix suggested that worked was a factory reset
It was okay after that...
mellorij
Message 3 of 17
Unfortunately I have tried a factory reset, but that has not helped 😞
My s/w appears to be the same version as yours:
02:37:26, 18 Dec.( 16.800000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
00:18:57, 18 Dec.( 17.030000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
21:38:37, 17 Dec.( 17.160000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
12:30:31, 17 Dec.( 17.270000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
03:47:50, 17 Dec.( 17.560000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
13:24:20, 16 Dec.( 17.260000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
09:17:06, 16 Dec.( 16.770000) Booting firmware 4.7.5.1.83.8.173.1.6 (Type A)
Barry57
Expert
Message 4 of 17
Hi mellorij
Could there be festive lights near the line / indoor or outdoor  ?  Flashing lights can be  troublesome this time of year.
If not  I'd raise a fault & see if the line checks come back with anything that might need an openreach visit.
https://www.bt.com/consumerFaultTracking/public/faults/reporting.do?pageId=21
Also check if there is anything up locally with openreach's new checker tool.
http://www.homeandwork.openreach.co.uk/problems-with-your-phone-or-broadband/search.aspx
If the test come back with no fault found, then possibly  research using a openreach modem with the hh5 or get a 3rd party non-bt all-in-one. These are the two main fixes people use on here.
You've probably noticed a few of simular threads about HH5 disconnects..
Happy xmas/hoildays dispite the line/hub mischief :smileyhappy:
pippincp
Sage
Message 5 of 17
Can we see lines 1-12 from the HH Troubleshooting/helpdesk page please?
mellorij
Message 6 of 17
Here you go, is my noise margin too high?
1. Product name:BT Home Hub
2. Serial number:+068343+NQ40219161
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 30/04/14
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 07:35:41
6. Data rate:9526 / 35000
7. Maximum data rate:9515 / 50782
8. Noise margin:6.2 / 9.5
9. Line attenuation:0.0 / 20.4
10. Signal attenuation:0.0 / 19.6
11. Data sent/received:331.8 MB / 1.4 GB
12. Broadband username:bthomehub@btbroadband.com
pippincp
Sage
Message 7 of 17
You have a fault on your line and need an engineer out to fix it. Time to make the phone call.
Target noise margin is 6.0.
mellorij
Message 8 of 17
Thank you, now reported.
Ian
Tony-gbr
Message 9 of 17
Replaced my hh5 with an open reach modem recently and an Asus router and no more disconnects. Engineer said the hh5 is rubbish and gets knocked offline by various interferences including Xmas trees.
imjolly
Message 10 of 17
Many hubs suffer from christmas lights being to close - it is not confined to the hh5
