mellorij
Message 11 of 17
Re: HUB 5 keeps rebooting
As an update, I reported a fault becuse the auto test found an in balance. This has now been fixed, but the hub is still rebooting. I have put the open reach router back and this still doesn;t help.
I'm going to try the Hub 3 now....
astar27
Expert
Message 12 of 17
Is your Hub 3 a TYPE A OR B?
mellorij
Message 13 of 17
Type "B"
Ian
pippincp
Sage
Message 14 of 17
And you haven't reposted lines 1-12 since the supposed fix because...
mellorij
Message 15 of 17
Becuase my wife had to work and needed a reliable connection. The Hub 3 appeared to be the quickest route.
pippincp
Sage
Message 16 of 17
If the HH3 works then why to change it?
mellorij
Message 17 of 17
I wanted to remove the Openreach modem and save some space and a plug socket!!!
