nothappyatall
Message 1 of 3
HUDSON 1500
Hello, I have just purchased a 3 hand set Hudson 1500.
Already it is a disaster.
Having fairly poor hearing, I opted for this equipment because it had an amplified message base.
As I said a disaster; with all volumes set to maximum, both on the base and hand sets, I can only hear tones 1&2, and then only barely, with my ear right up to the handsets, 3&4 are totally inaudible.
As a result of this, I have missed every incoming call over the couple of days I have had it installed. Most left no message on the answerphone, so I did not even hear that respond. One however did go to answerphone, but as I did not hear the call tone, only the answer phone working, by the time I got to it, the person had rung off.
I accept that my hearing is not the greatest, but the NTL triple set I have changed out, was pefectly audible to me, so it is a problem with the hudson.
Is there any way, short of clearing all my programming and returning the phones, that I can resolve this problem?
Any help appreciated.
2 REPLIES 2
nothappyatall
Message 2 of 3
Re: HUDSON 1500
Hello, I must rather sheepishly climb down from my high horse.
I have found that there were more than four ring tones, pity it was not more obvious though. Also as there were some that were much louder--The problem is now solved.
However, it is worth mentioning that there are needlessly laborious methods for adding phonebook entries to all hand sets, and why the **bleep** do missed calls show on every handset and have to be laboriousl removed from each in turn. That is some poor programming.
Regards
nothappyatall
Message 3 of 3
Re: HUDSON 1500
Finally, in the interests of clarity:
THe 'bleep' was used to edit out the home of Satan, talk about censorship.
Regards
