Bullitt
Distinguished Expert
Message 11 of 40
Re: Had BT Infinity Installed - Can't connect wirelessly?
whats the problem here
speeds or wireless?
Jyot
Message 12 of 40
well both but mainly wireless
speeds should go to normal after a few days
Bullitt
Message 13 of 40
can you see the homehub in your wireless network connections on the pc?
Jyot
Message 14 of 40
yh
Bullitt
Message 15 of 40
so what happens when you try to connect?
Jyot
Message 16 of 40
Says its connected but internet doesn't work
Bullitt
Message 17 of 40
what does this do? http://212.58.241.131/
DelSP10
Message 18 of 40
Are you using Windows 7 or Vista?
Possibly a Linux OS...............
If yes, set wireless network from public to home network.....
Jyot
Message 19 of 40
BBC - Public Service Message
Sorry, the address you are looking for is not available.
You will find almost all BBC public service content on http://www.bbc.co.uk/ and by following links to the content you require.
To access specific areas directly you can type the address in the format: http://www.bbc.co.uk/'service or programme title'
e.g. The Radio 1, BBC One and BBC Weather websites can be found at the following addresses:
Alternatively you can search bbc.co.uk:
Jyot
Message 20 of 40
using mac mountian lion 10.8.2
