Jyot
Message 1 of 40
Had BT Infinity Installed - Can't connect wirelessly?
Any help?
I cant connect through wifi but can through etherenet. I was promised 52 down and 13 up but when i do speed test through etherent, i get around 40 down and 6.5 up.
Any thing will help and i will gladly do any speed tests
Cheers
39 REPLIES 39
archies
Message 2 of 40
Re: Had BT Infinity Installed - Can't connect wirelessly?
Hi,
I had the same problem when i had mine installed, i thought it was the router at first but after a conversation with tech support they said everything was fine. I ended formatting my laptop, after i did this it connected straight away.
john46
Message 3 of 40
have you checked your wireless security codes are properly entered also your were given an estimate (Not Promised)of your speed an accurate speed is only ever known once a connection goes live if you run the diagnostic part of the BT speedtest and post the result here we can see your IP Profile then we can help further
http://speedtest.btwholesale.com/
Jyot
Message 4 of 40
43.05 Download
6.04 Upload
With Ethernet
Ping: 35.50
Jyot
Message 5 of 40
without: error 2032
john46
Message 6 of 40
Can you please run the full diagnostic test as asked for not the first test please
Jyot
Message 7 of 40
It says i have to wait 10 mins but when i did that earlier, it said no faults
john46
Message 8 of 40
can you please post the full results of that test when you can run it as we need to see your IP Profile and the second test shows it
Jyot
Message 9 of 40
Home Image not loadedTesting Image not loadedResult Image not loaded
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 40.45 Mbps
0 Mbps0 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 40.45 Mbps
 For your connection, the acceptable range of speeds is 12 Mbps-0 Mbps.
 IP Profile for your line is - 42.4 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 7.07 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 7.07Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit FAQ section if you are unable To understand the test results.
Jyot
Message 10 of 40
Sorry for the late reply, my ethernet also went but now is back but still no wireless
