john46
Message 31 of 40
Re: Had BT Infinity Installed - Can't connect wirelessly?
Hi This link may be of use to you http://forumhelp.dyndns.info/wireless/hh3link.html
Jyot
Message 32 of 40
After getting a new hub, my wireless still doesn't work 😞
ryant704
Guru
Message 33 of 40
What Wireless Adapter are you using?
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Jyot
Message 34 of 40
none- i have macbookpro
Devon_Dave
Distinguished Guru
Message 35 of 40
I guess that the fault is now not with the BT Equipment
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
robsonalan
Message 36 of 40
If you are able to connect to the wireless but Internet not working it would imply that either the default gateway or router isn't being set, or if not the DNS servers are not being set. I don't know about Mac OS but it could we to do with up settings. Is the adapter already set with a static ip, gateway and DNS. Make sure if there is a way that dhcp is turned on for all ip settings. Before you got infinity did you have another broadband supplier. Was your wireless working with that. Did you have to set you up details statically.
Jyot
Message 37 of 40
I think that it may be a problem with my mac as it works with all of my other wifi devices.
Even after the new router, no difference, i can connect using ethernet but not wireless.
I bought an adapter for my windows desktop and now even it can work wirelessly.
I guess i was calling the wrong people and am on the wrong forum lol 😉
ryant704
Guru
Message 38 of 40
Trying adding your default gateway, DNS, etc to your adapter settings
You could also trying using Googles DNS.
tidybrown
Message 39 of 40
Hi there Jyot... I just wondered if you got this sorted or not? I've had infinity installed today and like you everything works and connects all apart from my MacBook Pro... I could surf yesterday when with Sky Internet, now a new router with BT and can't connect wirelessly at all - via ethernet, no problems! Would be greatful to hear from you. Thanks
john46
Message 40 of 40
Have you removed all previous wireless networks from the device and the rescanned for wireless networks. Then entering the security code
