Message 1 of 2
Had to disable IPV6 on my WIFI
Due to a git and Azure DevOps issues I just had to disable IPV6 on my BT WIFI. Issue detailed here:
I'm still not sure why this issue has occurred and why disabling IPV6 fixes it. Does anyone here know the answer?
Tags (4)
1 REPLY 1
Message 2 of 2
Re: Had to disable IPV6 on my WIFI
You were given the answer to that over at the devcommunity.
"Azure DevOps honors all conditional access policies 100% for our Web flows. For third-party client flow, like using a PAT with git.exe, we support IP fencing policies only - we don't support MFA policies. And we only support IP fencing conditional access policies for IPv4 only. Conditional access policies set based on IPv6 are not supported today."
