Message 1 of 2
Hard drive replacement
Hi
My daughter's You View box is out of warranty & has died. The hard drive has almost certainly failed and I plan to replace this. Does anyone know what specification of hard drive is fitted to these? Its the new smaller size You View box. I assume its a 500GB SATA drive, but what physical size 2.5" or 3.5" and does the drive speed matter?
Many thanks
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Hard drive replacement
I suggest you have a look at the Youview community  -
One post that might be of use depending upon the model of box you intend to repair
https://community.youview.com/youview/topics/it-is-easy-to-replace-a-failed-hard-drive-in-the-youvie...
If your daughter is still has a BT TV contract or wants to take one out then contacting BT and getting a replacement or new box is an optyion you might want to consider.
