Bert93
Message 1 of 13
Has anyone used or heard of the DMT tool?
Has anyone on here used or heard of the DMT tool? if so? does it work?
___________________________________________________
Kind Regards, Bert
12 REPLIES 12
Distinguished Guru
Message 2 of 13
Re: Has anyone used or heard of the DMT tool?
Yes it does work. There are various versions of it and they only work with certain routers. Cannot remember the site its on . I think its the kitz site
{edit} here is the site:
http://www.kitz.co.uk/index.htm
toekneem
(EASBF)
Message 3 of 13
it is kitz  http://www.kitz.co.uk/routers/DMTv7.htm
Bert93
Message 4 of 13
which version would i need? 7, 8, 9? which version for homehub2?
Kind Regards, Bert
Message 5 of 13
you can do it to netgear as well using dgteam firmware
Message 6 of 13
won't work with hub
Bert93
Message 7 of 13
ok thanks imjolly im guessing i need th V7? sorry i posted then realised you had posted 😛
Kind Regards, Bert
Bert93
Message 8 of 13
ah man 😞 how not? any particular reason?
Kind Regards, Bert
Message 9 of 13
if it did everyone would be using it - it only works with certain routers.
as I said I use a netgear with dgteam firmware which enable me to adjust settings
Bert93
Message 10 of 13
shame it doesnt work, it'd be a fairly good piece of kit if it worked for HHs
Kind Regards, Bert
