Message 1 of 10
Has anyone ...............
Signed up for (and had activated) Infinity 2 when their estimated speeds have been the same (or lower) than what they are getting on the 40/10 profile ?
And if so, what are you getting ?
im currently getting
And have been estimated for the "upgrade"
Cheers 🙂
9 REPLIES 9
Message 2 of 10
Re: Has anyone ...............
Yes, see my message:-
http://community.bt.com/t5/BT-Infinity/Another-variation-of-the-80-mb-upgrade-problems/td-p/470341
I am awaiting a reply from the Mods and will ask for reversion back to my old contract if the download profile and speeds cannot be increased.
There has been no change in my actual speeds/profile since my initial message.
Message 3 of 10
Oh dear - hope you get that sorted :S
Message 4 of 10
Well mine went through last night and now getting (with modem and router re-boot)
Expert
Message 5 of 10
Re: Has anyone . . . Reboot the Hub
Mine was upgraded during the night from 37/8 on Infinity 2.
The upload speed had increased to 13.5 but not the download, until I restarted the home hub when the download was much better at about 70.
Now to see how it does over the next few days.
Richard
Message 6 of 10
Restarted my HH3 twice and still around the 45 meg mark -was hoping for in the 70's - but can't complain 🙂
Message 7 of 10
Just got home rebooted and tried agin with no real difference, however BT Speedtester now shows an upload profile of 20meg as opposed to 10 meg whereas my download profile has remained at c46meg - is there any chance of this increasing over teh next days days, given i seem to be able to achieve the full 20 meg upload (on profile) ?
Message 8 of 10
If you were predicted 38 and you're getting 46, more than likely not mate.
I think the IP profile for the upload is always set to the maximum that it can, regardless of actual connection rate.
Message 9 of 10
Mine was perfectly fine, I was told i would get speeds of 65/15 and have http://www.speedtest.net/result/1897700779.png
Message 10 of 10
I suspected as much 😛 Cheers and ill see where we're at in 10 days 🙂
