Message 21 of 26
Re: Have I been Duped?
@Aarong wrote:
Just to add buddy, looking at your speeds they aren't even in the acceptable range for download speeds, try http://www.speedtest.bbmax.co.uk/ and post results please mate. I would give them a call before hand if they are consistently that bad.
Sorry missed this post yesterday ill do this when home tonight and Post you the results!!!
Guru
Message 22 of 26
ok no worries buddy 😉
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 23 of 26
Ok the results are in! I have done two tests one via wirelss and the other Ethernet
Wireless http://www.speedtest.bbmax.co.uk/results.php?t=1336067713&v=15795620
Ethernet http://www.speedtest.bbmax.co.uk/results.php?t=1336067941&v=15795675
After getting such impressive results using the speedtest.bbmax i thought i would try Speedtest.net again and got the following
Wirless http://www.speedtest.net/result/1930319969.png
Ethernet http://www.speedtest.net/result/1930319969.png
All results definatly better for sure! Could it be that its finally settling down?
Message 24 of 26
Looking pretty decent 🙂
Guru
Message 25 of 26
Agree with Webby, looking a lot better here!
Message 26 of 26
it certainly is guys 🙂 ill continue to monitor but fingers crossed it stays like this.
Next thing to do is look at hard wiring the PS3.
Brillant Forum and Great people thanks to all
