jimbo59
Message 1 of 8
Have to keep resetting my hub
If i go to my site @ www.palsrock.org.uk after about five mins I have to reset my hub so I can get back on to it can anyone shed any light as to why or is it just my pc or hub need a kicking lol.
7 REPLIES 7
djh22
Recognised Expert
Message 2 of 8
Re: Have to keep resetting my hub
Does the problem only occur after visiting that website ?
monarchjock
Message 3 of 8
I have problems loading the website. Dead slow or nothing at all. Some of the links are the same.
Are you sure it's your hub that's the problem?
jimbo59
Message 4 of 8
yes
jimbo59
Message 5 of 8
by what you say sounds lke a server issue rather than hub
djh22
Recognised Expert
Message 6 of 8
But why would that cause the Hub to reset ?
jimbo59
Message 7 of 8
After spend good part of the day with my hosting company it is not them so it has to be a problem with hub spoke to call place out in India and she said it now sorted and yes for about a hour it ran ok no probs but now it back to how it was have to keep resetting the hub. never had this problem with virgin at the moment BT dont bother renewing my contract.
djh22
Recognised Expert
Message 8 of 8
I could write a book on my problems with VM before moving to BT but that's another story.
Have you tried another router ?  the settings for a non BT router are on page 54 here
Del.
