Noffy
Message 1 of 6
Have to keep resetting new hub
I have to reset my hub at least 3 times a week because the wireless speed drops to less than 1.5mbs, but, when I check the speed into the hub using the BT App it shows normal speed to the hub. Spoke with BT via chat and they said change channel etc and monitor for two days, same problem happens again. They said I need a new hub. This one is less than 4 months old! Spoke with BT technical this evening and they say it's working correctly and refuse to replace it! This is an annoying intermittent fault. Any body else have this problem?
Tags (1)
5 REPLIES 5
DanielS
Moderator
Moderator
Message 2 of 6
Re: Have to keep resetting new hub
Hi @Noffy,
What Home Hub are you using? Did you split the wireless networks as well as changing the wireless channels?
DanielS
Noffy
Message 3 of 6
Hi, I am using HH5 on infinity 1. Following on from an online chat with BT I moved the router to the main line in changed channels on both frequencies. The speed into the router was 47mbs and Ethernet was comparable. Wireless however drops intermittently to less than 1mbs down and 4mbs up and can only be resolved by resetting. Initially I had problems with tech support understanding this, one guy told me this week that he had fixed it and it would never happen again. It happened again yesterday, called tech support again and they have sent me a replacement hub. Let's see if it is a faulty router.
PaddyB
Moderator
Moderator
Message 4 of 6
Hi @Noffy,
Thank you for posting back. Let us know how you get on with the replacement Hub.
PaddyB
Noffy
Message 5 of 6
Hi, just to let you know that the exchanged HH 5 is working very well. I am constantly getting an average of 36mbps wirelessly. I have noted that this router is series A rather than a B like the last one. Not sure what the difference is though.
licquorice
Message 6 of 6
Different manufacturer and chipset.
