Enhesa
Message 1 of 3
Have to reset router and modem every day to get my top speed
Hi all,
So every time I come home from work I do a speed test and I'm throttled at about 1mbps, I unplug both my router and modem, plug back in and I get 30 odd mbps. This fix works without fail every time, but it's a massive pain in the ass. I'm on infinity 1
Any quick ideas?
Cheers
2 REPLIES 2
ray_dorset
Distinguished Guru
Message 2 of 3
Re: Have to reset router and modem every day to get my top speed
In order to rule out the Homehub as potentially being the device responsible for your speed loss, you can connect the Openreach modem directly to the PC and see if the speed improves.
To do that follow these steps:
Step 1: Remove the homehub from the modem cable
Step2: Connect your pc/laptop to the modem via the cable instead
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4: Connect to the internet then click make a new connection Broadband PPPoE
Step5: Username bthomehub@btbroadband.com and the password as BT
Step6: connect, If it doesn't,keep pressing try again until it does.
However, please note that this will stop any other access apart from the PC
If not, I'll try again 🙂
Barry57
Expert
Message 3 of 3
If the hub is ruled out as Ray Highlights first
Posted this on a similar thread.
"Its a fault with the Openreach modem (or the power plug maybe?) mine says connected no problem for weeks.
I'm not sure BTRetail still send openreach out for modems anymore,  just send a hh5 out these days ?
Also just check BTRetail don't recontract for another 12/18m  if sending a free hh5.  {Its a fault not an upgrade}
If you don't fancy the Stress/time off ect dealing BTretail/Openreach , there are loads of openreach modems on certain auction sites ect"
https://community.bt.com/t5/BT-Infinity-Speed-Connection/bt-infinity-openreach-modem-needs-power-cyc...
