Gis
Newbie
Message 1 of 2
Have to set my Router 2.0 to factory settings to work on an Aspire notebook running Linux
My router works very well on my desktop running XP and has done for several months. However I regularly have to reste the router to factory settings so that the Aspire notebook, running Linux, will connect to the network. I make no other changes to the router configuration, and I am not aware that I have changed anything ever, except enabling power saving. Any ideas please?
1 REPLY 1
Message 2 of 2
Re: Have to set my Router 2.0 to factory settings to work on an Aspire notebook running Linux
have you made sure that the wifi driver in your netbook is up to date?  using your pc download inssider2 from metgeek and run it.  It will show the networks round about you including your own and also the channels others are using.  if you are on a popular channel then change to another channel or at least one that is less congested.
you could also chnage from b/g/n to just b/g in the hub which may help
