Message 1 of 5
Having a problem connecting to some web pages
Had similar issues in the past and usually something on the path is broken. Anyway it's very slow right at the start, as can be seen from the tracert:
4 REPLIES 4
Message 2 of 5
Re: Having a problem connecting to some web pages
There is nothing wrong with that tracert.
Message 3 of 5
Nothing wrong? I compared to another site; that had only 1 time out and then 6 steps all of 20ms.
Perhaps you could explain a little?
Message 4 of 5
The only relevant part of a tracert is the response from the destination. If that is OK then the rest is immaterial.
Message 5 of 5
Hi @Thorsson as @pippincp  says there is nothing wrong with that tracert , it just shows the first two nodes are configured not to reply to being pinged.
