Morning,
My devices keep dropping off from my routers WiFi. At least once a day. This started just over a week ago, and i had a brand new spare HomeHub2 in the cupboard so threw the old one out and plugged the new one in. But obviously i'm still having the same problem. My wired connection is fine however, and works perfectly all the time. My phone/laptop can see the routers Wifi, but it just wont connect to it. Resetting the router with the side buttons cures the issue and its good for a while, maybe a whole day.
Used WifiAnalyzer and can see my router (seems to have 4 entries, 2 BTHomeHub 2-S54G, a BTFon, and a BTOpenzone). All on channel 6.
Then 2 entries on channel 1 For A HomeHub6-5M9R, BTwifi with Fon.
So doesn't seem to congested??
But It feels like theres interference somehow, as this just started suddenly and with 2 differet routers. Had elderly neighbours moved in just after christmas, maybe they've recently bought something to cause this issue?
Anything I can do to help stay connected to my WiFi,
Many thanks.
Mark.
Solved! Go to Solution.
Try the usual fixes for the home hub, in this order.
factory reset the home hub.
Then turn Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/443
Then separate and rename the SSIDs.
http://bt.custhelp.com/app/answers/detail/a_id/447
Thanks for the quick reply.
I have a HomeHub2 and when i tyoe the address in the address bar i do not get the screen you show to turn off Smart Setup. Infact i can't find it anywhere on the page i see, even after searching using the A-Z fields.
Mark
Which home hub 2 do you have, is it the old home hub 2 for normal broadband, or the new Smart Hub 2?
The old home hub 2 does not have smart setup.
You can try manually changing wireless channels to avoid channel 6. Try channel 13.
There's no channel 13. Only goes up to 11.
Its on Auto at the moment obviously, on channel 6. But I do seem to be the only one in range using that channel. Other signals are on channel 1.
Edit, acutually its not automatic, its set to channel 6.
If its the old home hub, then you have to change the channel selection to manual, then you can select any channel.
The old home hub 2s had lots of issues with the internal wireless units, which is why BT replaced them with the home hub 4, which is also dual band.
If you are still in a contract with BT Retail, then you could ask them for a home hub 4, or buy your own third party router. A single band unit costs about £40.
A third party router will not transmit those extra wireless SSIDs, as they can cause issues with some wireless devices.
