Zombie
Expert
Message 1 of 13
Hello all, move question.
Hi I have ordered bt infinity 2 I have been a sky fibre customer for years and fibre max for couple more. Currently my router syncs at 79987 down and 20000 up, and a throughput of 75. Is that likely to be similar with bt.
Can i ask is my move over just a simple software change or does it involve the physical moving of cables at the cabinet or exchange. I am however hopeful after reading posts if I have any problems with my connection the forum members and mods do offer help, which would be a big plus for me as I can't use the phone to call bt help desk ect as I'm deaf. So naturally I am slightly worried about any change.
Thank you.. Zombie.
12 REPLIES 12
Webby
Message 2 of 13
Re: Hello all, move question.
You'll be allocated a different port in the cabinet.
Other than that, the physical networo doesn't change, so there should be no reason your speeds will be any different.
RogerB
Guru
Message 3 of 13
It's also worth mentioning that BT and Sky will use slightly different algorithms to control the linespeed. But if your line was fault free with Sky it should be fault free with BT, but you may notice a slight drop in speed as stated but not worth mentioning.
Zombie
Expert
Message 4 of 13
Thanks Webby that's reassuring it only a port change. Hopefully it will be a good one.
RogerB
Guru
Message 5 of 13
There's actually very little difference in port efficiency inside the dslam, they will all be subject to roughly the same levels of crosstalk if it exists within.
Zombie
Expert
Message 6 of 13
Thanks RogerB appreciated, a slight drop should be no problem as long as I can video sign with friends and family and download / upload messages from the cloud, keep my door cctv, fire alarms ect live it should be fine. My old fibre 40/10 from a couple of years ago did start to struggle luckily fibre max was just starting to be rolled out in my area. I don't think I have had any faults on my line but I wouldn't know.
RogerB
Guru
Message 7 of 13
You would soon get to know ... as line noise, crackle or impulse noise will soon deteriorate the connection, but nothing should change even though you're changing supplier as the line is the same, and it's on the same network as mentioned. But the only change is line algorithms that run it. BT's tend to be a tad critical moreso than alternative providers, but as said if the line is fine, it should be ok to go ... but maybe expect a slight drop in linespeed, perhaps. If not ... good. e.g. it may use 3-4 megs more overhead .... nothing. And if that's the case don't worry about it, it'll not affect good throughput.
Zombie
Expert
Message 8 of 13
Thank you very much.
licquorice
Message 9 of 13
Its actually the reverse Roger, BT implement a 'Speed' DLM profile whilst Sky implement the 'Standard' profile.
Zombie
Expert
Message 10 of 13
I think I tapped on solved whist scrolling, not to worry you have both been very helpful, many thanks.
Zombie.
