Help Configure the IPv6 Internet setting of DSL-AC68U.
Here are the options available to me.
Basic Config:
Connection type: (Options) Native/Static IPv6/Passthrough/Flet's IPv6 service/Tunnel 6to4/Tunnel 6in4/Tunnel 6rd
Interface: (Options) PPP/Ethernet
DHCP-PD: (Options) Enable/Disable
Accept Default Route: (Options) Enable/Disable
IPv6 LAN Setting:
LAN IPv6 Address
LAN Prefix Length
LAN IPv6 Prefix
Auto Configuration Setting: (Options) Stateless/Stateful
IPv6 DNS Setting:
Connect to DNS Server automatically: (Options) Enable/Disable
Personal Note: I will most likely disable so I can use Quad9 DNS Servers.
Enable Router Advertisement: (Options) Enable/Disable
ASUS IPv6 FAQ.
https://www.asus.com/support/FAQ/113990
Basic Config:
IPv6 LAN Setting:
LAN IPv6 Address
LAN Prefix Length
LAN IPv6 Prefix
IPv6 DNS Setting:
They're the settings I use on my 68U which works just fine.
Any progress?
