donali1963
Message 1 of 4
Help Deleting Email Addresses
Good morning.  I have pghoned the call centre a number of times but do not appear to be getting anywhere.  I am currently using 11 of my 11 email addresses and would like to delete 4 of them which are no longer used.  When I press the button to 'Delete' the addresses, nothing happens.  I have been trying since August to delete these addresses but still no luck.  Can anyone help me?
3 REPLIES 3
RobbieMac
Moderator
Moderator
Message 2 of 4
Re: Help Deleting Email Addresses
Hi @donali1963
Thanks for your post and welcome back!
Sorry for the problems you're having deleting those email address.  The community won't be able to help with this so we will give you a hand from here.
Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
donali1963
Message 3 of 4
Hi.  I'm not sure what to look for when I click the name.  can you be more specific?
licquorice
Message 4 of 4
