Newbie
Message 1 of 3
Help! Home Hub 4 Not connecting to HP photosmart 5520
Have just recieved the new homehub 4, have intenet access and wifi around the house on both ipads.
The HP photosmart 5520 will print from the ipads, but i canont get it to print or connect wirelessly to my main PC.
I have restarted printer, home hub, pc
I have reset settings on home hub, reentered the passowrd along with presing the WPS button on the top
I have treid doing diagnostics from control panel / printers and it says the printer is not connected.
Can anyone help or has anyone had a similar issue as i reaaaly need to print 🙂
2 REPLIES 2
Message 2 of 3
Re: Help! Home Hub 4 Not connecting to HP photosmart 5520
have you tried reinstalling the printer on the pc?
Newbie
Message 3 of 3
Superb! I downloaded the software, installed it, but it could not find the printer, it said network connection error, but i carried on to the end of the install / help. Tried to do a test print, it came up 'cant print / erorr....then printed!! How bizzare! Its working on both printer and ipad now. THANKYOU! 🙂
