Have just recieved the new homehub 4, have intenet access and wifi around the house on both ipads.
The HP photosmart 5520 will print from the ipads, but i canont get it to print or connect wirelessly to my main PC.
I have restarted printer, home hub, pc
I have reset settings on home hub, reentered the passowrd along with presing the WPS button on the top
I have treid doing diagnostics from control panel / printers and it says the printer is not connected.
Can anyone help or has anyone had a similar issue as i reaaaly need to print 🙂
Solved! Go to Solution.
have you tried reinstalling the printer on the pc?
Superb! I downloaded the software, installed it, but it could not find the printer, it said network connection error, but i carried on to the end of the install / help. Tried to do a test print, it came up 'cant print / erorr....then printed!! How bizzare! Its working on both printer and ipad now. THANKYOU! 🙂
