Message 1 of 22
Help Needed with Master Socket Wiring
Hi All,
I need some help wiring up my master phone socket. I was having some broadband issues a few weeks ago and to determine whether or not the problem was with my ISP or Phone Line I took off the front of the socket to plug my router/phone into the test port as I had no internet through the normal port (it ended up being an ISP problem). Long story short I had the phone cable plugged into the normal socket but hadn't screwed the fascia back on, stood up caught my foot in the phone cable and ended up pulling some of the wires out (I can only get a phone line and broadband through the test port not the main port). The phone line still works through the main socket but my internet doesn't, so I can only assume I've disloged a wire for this?
Here is a photo of the socket as it currently looks:
I have the following wires avaiable:
Blue/White - Not connected
Green/White - Not connected
Orange/White - Not connected
Orange - Connected to pin 5
Black - Connected to pin 5
Blue - Connected to pin 2
Light Green - Connected to pin 2
Dark Green - Connected to pin 3
Any help/advice appreciated! Do I need to buy a specialist tool to get the wires in their appropriate sockets?
Thanks,
James
21 REPLIES 21
Message 2 of 22
Re: Help Needed with Master Socket Wiring
the wires connected to the front plate are your extension sockets and should be connected to terminals 2 & 5.  easiest way to make sure right wire to right conenction is to check your extension sockets and see which wire goes to 2 and which to 5 and then wire accordingly.   you may need an IDC tool to locate the wires back
Distinguished Guru
Message 3 of 22
Mmm
Strange wiring at the moment.
I assume you have not re terminated any of the wires, Do you have an outside extension bell? (black/green pair)
Can you check what colours are being used on your extension socket.
Note for self, must type quicker than IMJSmiley Embarassed
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 22
you must be really slow then - or maybe I just read it before you  LOL Smiley Very Happy
Message 5 of 22
Thanks for the reply, no I've not touched the existing wiring (I wouldn't have a clue where to start!).
There is a black wire going to terminal 5 and 3 different green wires (green/white, dark green and light green) but none of them are paired off, they're just loose single wires.
I've just had a look at one of the extension sockets and it has the following wires connected up (I can post a photo if it helps):
Orange to terminal 5
Blue to terminal 2
Green to terminal 3
Thanks,
James
Message 6 of 22
Blue to terminal 2
Green to terminal 3
Thanks,
James
then you should have an orange wire on 5 and a blue on 2 in master and I would disconnect bellwire on 3 in both
Distinguished Guru
Message 7 of 22
Wiring seems ok (although not standard colours, there may have been a fault at some point and someone has substituted the wire on term 5) I assume that you have plugged the frontplate back in when trying to get dial tone on the extension socket?
Message 8 of 22
you need to look at other extension sockets as it appears the socket disconneted is cnot the one you have looked at as orange and blue are still connected
Message 9 of 22
Hi Guys,
Thanks for your help with this, I've just double checked the dial tone with the front plate screwed back in and there's nothing.
I've gone around and looked at all 3 extension sockets.
Extension 1
Solid blue to terminal 2
Solid green to terminal 3
Solid orange to terminal 5
Extension 2
Solid white to terminal 2
Extension 3
I can't get a dial-tone or ADSL through any of the extensions.
Hope that's of some help!
Thanks,
James
Message 10 of 22
are you getting anything at master if the faceplate is replaced - should work regardless
