Hi @toonlass,
We will be able to look into everything on our side and do our best to help you. To reach us, click on my user name and then on contact the mods. It'll take us a couple of working days before we can get back in touch.
@RogerB, @Keith_Beddoe, @john46, thanks for taking the time to help with this. We have a lot of information which will come in very useful.
DanielS
Hi @toonlass Thanks for taking my call earlier and good to hear that the connection has now been very stable for the last few weeks and we can close the fault. If the problem comes back do let us know and we will be happy to help.
cheers
John
Hello
Thank you so much for your help - i really thought we had got somewhere. Unfortunately after 2/3 weeks of consistent good speeds (3.3mbps) and closing the fault with you thursday we have again had the return of low speeds for no apparent reason.
This is the router stats (wired):
System Up Time 557:26:07 | ||||||||||||||||||||||||||||||||||||||||||||||
The BT wholesale test (wired) tells me:
Download speedachieved during the test was - 1.15 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :4.26 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 3.5 Mbps
No faults are reported in our area. Quiet line test is quiet!
Any further help would be appreciated!
8am this morning - wired. The previous stats were at 7pm
Download speedachieved during the test was - 2.48 Mbps
System Up Time 593:25:40
Port | Status | TxPkts | RxPkts | Collisions | Tx B/s | Rx B/s | Up Time |
WAN | PPPoA | 87897983 | 118237057 | 0 | 1264 | 194 | 369:45:04 |
LAN1 | 100M/Full | 39345473 | 32205751 | 0 | 4689 | 895 | 593:25:18 |
LAN2 | 1000M/Full | ||||||
LAN3 | Link down | ||||||
LAN4 | 100M/Full | ||||||
WLAN b/g/n | 145M | 197614212 | 154118594 | 0 | 23081 | 15045 | 38:52:22 |
WLAN a/n/ac | 867M | 31650639 | 23387245 | 0 | 11167 | 17104 | 38:52:15 |
ADSL Link | Downstream | Upstream |
Link Rate | 4256 Kbps | 448 Kbps |
Line Attenuation | 45.0 dB | 31.0 dB |
Noise Margin | 7.6 dB | 19.0 dB |
Yes I am using the test socket when posting the stats
