DanielS
Moderator
Moderator
Message 51 of 68
Re: Help! Really stuck as to what is causing drop in speeds...
Hi @toonlass,
We will be able to look into everything on our side and do our best to help you. To reach us, click on my user name and then on contact the mods. It'll take us a couple of working days before we can get back in touch.
@RogerB@Keith_Beddoe@john46, thanks for taking the time to help with this. We have a lot of information which will come in very useful.
DanielS
JohnC2
Moderator
Moderator
Message 52 of 68
Hi @toonlass Thanks for taking my call earlier and good to hear that the connection has now been very stable for the last few weeks and we can close the fault. If the problem comes back do let us know and we will be happy to help.
cheers
John
toonlass
Message 53 of 68
Hello
Thank you so much for your help - i really thought we had got somewhere.  Unfortunately after 2/3 weeks of consistent good speeds (3.3mbps) and closing the fault with you thursday we have again had the return of low speeds for no apparent reason.
This is the router stats (wired):
System Up Time 557:26:07
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANPPPoA6340597185408040030581152333:45:30
LAN1100M/Full350672892875638202651386557:25:44
LAN21000M/Full
LAN3Link down
LAN4100M/Full
WLAN b/g/n145M166295015130801514028313235464102:52:48
WLAN a/n/ac867M3091561823008364011047722312602:52:41
ADSL LinkDownstreamUpstream
Link Rate4256 Kbps448 Kbps
Line Attenuation45.0 dB31.0 dB
Noise Margin6.1 dB19.0 dB
The BT wholesale test (wired) tells me:
Download speedachieved during the test was - 1.15 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :4.26 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 3.5 Mbps
No faults are reported in our area.  Quiet line test is quiet!
Any further help would be appreciated!
Tags (1)
Webby
Message 54 of 68
Wired or wireless?
john46
Message 55 of 68
The OP posted the speedtest is wired
RogerB
Guru
Message 56 of 68
It's a possibility some VLANs have been under pressure last 2-3 days, what with Youtube streaming Crufts etc. ... or maybe on a congested VLAN anyways, normally. If it gets better after Sunday, you'll know. If not, back to the drawing board and moderator assistance with BTw.
toonlass
Message 57 of 68
8am this morning - wired. The previous stats were at 7pm
 Download speedachieved during the test was - 2.48 Mbps
System Up Time 593:25:40
WANPPPoA8789798311823705701264194369:45:04
LAN1100M/Full393454733220575104689895593:25:18
LAN21000M/Full
LAN3Link down
LAN4100M/Full
WLAN b/g/n145M1976142121541185940230811504538:52:22
WLAN a/n/ac867M31650639233872450111671710438:52:15
Noise Margin7.6 dB19.0 dB
RogerB
Guru
Message 58 of 68
Are you in the test socket with the hub/modem?
toonlass
Message 59 of 68
toonlass
Message 60 of 68
Yes I am using the test socket when posting the stats
