toonlass
Message 61 of 68
Re: Help! Really stuck as to what is causing drop in speeds...
Still slow today - stats below wired, 1:20pm
 Download speedachieved during the test was - 1.74 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :4.26 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 3.5 Mbps
System Up Time 647:05:47
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANPPPoA12519180216974494002542600423:25:10
LAN1100M/Full4184408334059084033021184647:05:24
LAN21000M/Full
LAN3Link down
LAN4100M/Full
WLAN b/g/n145M252033737194233054010862719792:32:28
WLAN a/n/ac867M326062372381755906269741392:32:21
ADSL LinkDownstreamUpstream
Link Rate4256 Kbps448 Kbps
Line Attenuation45.0 dB31.0 dB
Noise Margin6.9 dB19.0 dB
toonlass
Message 62 of 68
 It took a few attempts using the wholesale speedtest - i got time out errors and error 2032 in case that helps?
LAN21000M/Full
LAN3Link down
LAN4100M/Full
toonlass
Message 63 of 68
not chnaged anything but back to good speeds again now at 4:15pm
the 2.34mbps is now reflected on other devices - wired and non-wired.  Can anyone see any obvious differences between my earlier posting today and this one?
Download speedachieved during the test was - 2.34 Mbps
System Up Time 649:57:47
WANPPPoA12680511617191828703291790426:17:10
LAN1100M/Full4428782835915492028301315649:57:24
LAN21000M/Full
LAN3Link down
LAN4100M/Full
WLAN b/g/n145M252162739194342583010740708195:24:28
WLAN a/n/ac867M326806842385298206264720495:24:21
Noise Margin7.7 dB
19.0 dB
RogerB
Guru
Message 64 of 68
Yes, it seems to do better with a greater margin ... although I think the moderators ought to check the VP on your connection. Don't do anymore BT tests today .... and we'll see if the mods pick this up again. You may need either another pair (if there is one) ... or a change of virtual path on the connection.
toonlass
Message 65 of 68
Thank you - it has gone back to being slow now this evening
RogerB
Guru
Message 66 of 68
For the sake of curiosity ... post your stats as they are now ....
toonlass
Message 67 of 68
Sorry I missed your message last night, the connection has been poor all day.  7:30pm this evening, wired:
 Download speedachieved during the test was - 2.43 Mbps
 Your DSL Connection Rate :4.45 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
System Up Time 677:15:03
WANPPPoA11166798144225820190754860917:38:04
LAN1100M/Full4597305337330667032261651677:14:40
LAN21000M/Full
LAN3Link down
LAN4100M/Full
WLAN b/g/n145M276537509213436921063671229122:41:44
WLAN a/n/ac867M3324893924114431058025676122:41:37
Link Rate4448 Kbps448 Kbps
Line Attenuation44.5 dB30.5 dB
Noise Margin5.3 dB19.0 dB
DavidM
Moderator
Moderator
Message 68 of 68
Hi @toonlass and thanks for posting.
I can see @OlgaC is dealing with this for you. She's out of the office until Tuesday but has scheduled a call back for that day. I'll let her know you're posted.
Cheers
David
